Aller au contenu principal
Info : Vous modifiez actuellement un pré-requis du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 52 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 18
Étape 18
Insert a new opening pick and slide it to the middle of the right edge of the iPad, releasing the adhesive as you go. The display cables are located approximately halfway from the bottom of the iPad. Stop sliding the pick when you get ~4.5" from the bottom of the iPad. The display cables are located approximately halfway from the bottom of the iPad. Stop sliding the pick when you get ~4.5" from the bottom of the iPad.
  • Insert a new opening pick and slide it to the middle of the right edge of the iPad, releasing the adhesive as you go.
  • The display cables are located approximately halfway from the bottom of the iPad. Stop sliding the pick when you get ~4.5" from the bottom of the iPad.
Insérez le nouveau médiator et déplacez le vers milieu du coté droit de l'iPad, afin de retirer l'adhésif.
Les câbles de l'écran sont approximativement situées dans la moitié inférieur de l'iPad. Ne déplacez plus le médiator quand vous arrivez à environ 10 cm du bas de l'iPad.
[* black] Insert a new opening pick and slide it to the middle of the right edge of the iPad, releasing the adhesive as you go.
[* icon_caution] [guide|88071|Thehttps://d3nevzfk7ii3be.cloudfront.net/igi/lwAVndGwbUvVYSmI.large|The display cables|stepid=62527|new_window=truecables|new_window=true] are located approximately halfway from the bottom of the iPad. Stop sliding the pick when you get ~4.5" from the bottom of the iPad.
