Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Anglais
Français
Traduction de l’étape 3
Étape 3
Use the pointed tip of a spudger to lift the power button out of its housing in the rear case. At this point, the volume button bracket may lift out of its slot. Do not remove it entirely as the ribbon cable is still glued to the rear case. At this point, the volume button bracket may lift out of its slot. Do not remove it entirely as the ribbon cable is still glued to the rear case.
  • Use the pointed tip of a spudger to lift the power button out of its housing in the rear case.
  • At this point, the volume button bracket may lift out of its slot. Do not remove it entirely as the ribbon cable is still glued to the rear case.
Utilisez la pointe d'un spudger pour pousser le bouton de marche à travers son emplacement dans la coque arrière.
À ce stade, le support du bouton de volume pourrait sortir de sa fente. Ne le retirez pas complètement, car la nappe est encore collée à la coque arrière.
