Aller au contenu principal
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront le tutoriel qui comprend ces étapes.
Anglais
Français
Traduction de l’étape 10
Étape 10
While the battery is still connected, lift the bottom end of the battery up. Use tweezers to pull all of the adhesive liners off. Carefully lower the battery back into place and press against the edges to activate the adhesive.
  • While the battery is still connected, lift the bottom end of the battery up.
  • Use tweezers to pull all of the adhesive liners off.
  • Carefully lower the battery back into place and press against the edges to activate the adhesive.
  • Use a spudger to pry up and disconnect the battery connector from the motherboard and bend it away slightly.
  • Continue with the reassembly process.
Insérez ici votre traduction
