Aller au contenu principal
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront les 4 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 3
Étape 3
Flip the console over so the bottom is facing up. Use a T8 Torx Security  screwdriver to remove the three black 7mm screws in the back panel. Remove the bottom cover in the same way as the top cover. Grip the cover on both sides and pull up until it clicks. Then slide the cover off.
  • Flip the console over so the bottom is facing up.
  • Use a T8 Torx Security screwdriver to remove the three black 7mm screws in the back panel.
  • Remove the bottom cover in the same way as the top cover. Grip the cover on both sides and pull up until it clicks. Then slide the cover off.
Insérez ici votre traduction
