Aller au contenu principal
Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 4 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 2
Étape 2
Use a T8 Torx Security screwdriver to remove five screws from the rear of the device. Two 31mm screws. Three 10mm screws for the 7000 models; Two gray 10mm screws (upper and lower screws on the illustration) if the PS4 Pro is a 7100-series model.
  • Use a T8 Torx Security screwdriver to remove five screws from the rear of the device.
  • Two 31mm screws.
  • Three 10mm screws for the 7000 models; Two gray 10mm screws (upper and lower screws on the illustration) if the PS4 Pro is a 7100-series model.
  • Remove the metal plate by pulling it up.
Utilisez un tournevis de sécurité Torx T8 pour retirer cinq vis à l'arrière de l'appareil.
Deux vis de 31 mm.
Trois vis de 10 mm.
Retirez la plaque métallique en la tirant vers le haut.
[* black] Use a T8 Torx Security screwdriver to remove five screws from the rear of the device.
[* red] Two 31mm screws.
[* orange] Three 10mm screwsscrews for the 7000 models; Two gray 10mm screws (upper and lower screws on the illustration) if the PS4 Pro is a 7100-series model.
[* black] Remove the metal plate by pulling it up.
