Aller au contenu principal
Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 4 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 3
Étape 3
Flip the console over so the bottom is facing up. Use a T8 Torx Security  screwdriver to remove the three black 7mm screws in the back panel. (7000-series models only); or one 7mm screw (the middle one) with 7100-series models and the warranty sticker to the left. Remove the bottom cover in the same way as the top cover. Grip the cover on both sides and pull up until it clicks. Then slide the cover off; With 7100-series models, pay attention to the two clips that replace the corresponding screws.
  • Flip the console over so the bottom is facing up.
  • Use a T8 Torx Security screwdriver to remove the three black 7mm screws in the back panel. (7000-series models only); or one 7mm screw (the middle one) with 7100-series models and the warranty sticker to the left.
  • Remove the bottom cover in the same way as the top cover. Grip the cover on both sides and pull up until it clicks. Then slide the cover off; With 7100-series models, pay attention to the two clips that replace the corresponding screws.
Retournez la console de sorte que le bas soit orienté vers le haut.
Utilisez un tournevis de sécurité Torx T8 pour retirer les trois vis noires de 7 mm du panneau arrière.
Retirez le capot inférieur de la même manière que le capot supérieur. Saisissez le couvercle des deux côtés et tirez vers le haut jusqu'à ce qu'il s'enclenche. Faites ensuite glisser le couvercle.
[* black] Flip the console over so the bottom is facing up.
[* red] Use a T8 Torx Security screwdriver to remove the three black 7mm screws in the back panel. (7000-series models only); or '''one''' 7mm screw (the middle one) with ''7100-series'' models '''and''' the warranty sticker to the left.
[* black] Remove the bottom cover in the same way as the top cover. Grip the cover on both sides and pull up until it clicks. Then slide the cover offoff; '''''With 7100-series models,''''' pay attention to the two clips that replace the corresponding screws.
