Aller au contenu principal
Anglais
Français
Traduction de l’étape 6
Étape 6
If you have  a stereo microscope you should go over the board to look for damaged components or broken solder joints.  If no microscope is available this would be a good time to loosely reassemble the unit and see if you have a good result.  If the unit has visible issues board level you may want to consider finding a professional  repair option.
Inspection, Inspection and more Inspection.
  • If you have a stereo microscope you should go over the board to look for damaged components or broken solder joints. If no microscope is available this would be a good time to loosely reassemble the unit and see if you have a good result. If the unit has visible issues board level you may want to consider finding a professional repair option.
Si vous avez un microscope, examinez la carte à la recherche de composants endommagées ou de joints de soudures cassés. Sinon, c'est le bon moment pour remonter l'appareil et de voir si vous obtenez de bons résultats. Si votre carte mère présente des dommages visibles, vous devriez envisager de consulter un réparateur professionnel.
