Aller au contenu principal
Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 4 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 6
Étape 6
Disconnect the trackpad ribbon cable by lifting the ZIF connector lock with a  small prying tool or fingernail and gently pulling the ribbon cable straight out of its socket. Disconnect the trackpad ribbon cable by lifting the ZIF connector lock with a  small prying tool or fingernail and gently pulling the ribbon cable straight out of its socket. Disconnect the trackpad ribbon cable by lifting the ZIF connector lock with a  small prying tool or fingernail and gently pulling the ribbon cable straight out of its socket.
  • Disconnect the trackpad ribbon cable by lifting the ZIF connector lock with a small prying tool or fingernail and gently pulling the ribbon cable straight out of its socket.
Débranchez le câble ruban du trackpad en soulevant le verrou du connecteur ZIF avec un petit outil ou un ongle et en tirant doucement le câble ruban directement hors de sa prise.
