Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Anglais
Français
Traduction de l’étape 17
Étape 17
Use a spudge to remove the tape/sticker. Be very gentle and careful with this step because the connector is a hard-to-remove ribbon cable with a bunch of small cables. Ripping one of them will damage the ribbon cable, and will cause bad or no screen. It is recommended to use an IC extractor to remove the LCD connector  (however, you can use two small flat-had screwdrivers, or tweezers to slide the connector out o the socket).
removing LCD cable
  • Use a spudge to remove the tape/sticker.
  • Be very gentle and careful with this step because the connector is a hard-to-remove ribbon cable with a bunch of small cables. Ripping one of them will damage the ribbon cable, and will cause bad or no screen.
  • It is recommended to use an IC extractor to remove the LCD connector (however, you can use two small flat-had screwdrivers, or tweezers to slide the connector out o the socket).
Insérez ici votre traduction
