Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Anglais
Français
Traduction de l’étape 20
Étape 20
Remove the golden antenna cable from the socket. Be very careful, and use a spudger. Remove the screw. The WiFi module will jump up when the screw is removed. Slide the WiFi module out.
removing the bad Wifi module.
  • Remove the golden antenna cable from the socket. Be very careful, and use a spudger.
  • Remove the screw.
  • The WiFi module will jump up when the screw is removed. Slide the WiFi module out.
  • Wear gloves to avoid touching the antenna or the antenna sockets.
  • To install the new Wifi module, slide the new WiFi module in , push it down, and put the screw back in.
  • Attach the antenna back in.
Insérez ici votre traduction
