Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Anglais
Français
Traduction de l’étape 21
Étape 21
In this case I did not remove the main PCB because then I had to remove the DC jack. It was a very breakable connector, and the wires are very thin. If you break one of them you cannot charge your laptop any more. If the DC jack is damaged or broken in your laptop, remove the hinge instead (this is holding the DC power jack in place). If the DC jack is damaged or broken in your laptop, remove the hinge instead (this is holding the DC power jack in place).
removing main PVB
  • In this case I did not remove the main PCB because then I had to remove the DC jack. It was a very breakable connector, and the wires are very thin. If you break one of them you cannot charge your laptop any more.
  • If the DC jack is damaged or broken in your laptop, remove the hinge instead (this is holding the DC power jack in place).
Insérez ici votre traduction
