Aller au contenu principal
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront les 10 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 2
Étape 2
Insert the plastic opening tool into the  gap between the bottom of the case and the grated top side. Then find the clips in between that hold the case in place.
  • Insert the plastic opening tool into the gap between the bottom of the case and the grated top side. Then find the clips in between that hold the case in place.
  • Use the opening tool to pop the clips out. The best method is to pry the black case away from the bottom.
  • You will hear clicking sounds when you are prying the case open. It may be fairly difficult to remove the bottom.
  • It's possible that the clips may break when you remove the bottom from the case.
  • We recommend starting at one corner and sliding the prying tool along the edges of the Xbox One S. Once the first few clips are opened you can lift the cover up to find the remaining clips.
Insérez ici votre traduction
