Aller au contenu principal
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront les 10 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 5
Étape 5
Insert an opening tool gently between the top cover and metal casing on both sides to prepare the cover for removal. This step is necessary because you need to pry interior rivets away from the exterior case. The interior rivets that hold the case in place are circled in the last image. After you gently pry in the areas demonstrated, the side panel of the exterior case will be able to come off of the rest of the casing. Look at the image in Step 7 for clarification on how the exterior case disassembles.
  • Insert an opening tool gently between the top cover and metal casing on both sides to prepare the cover for removal.
  • This step is necessary because you need to pry interior rivets away from the exterior case. The interior rivets that hold the case in place are circled in the last image. After you gently pry in the areas demonstrated, the side panel of the exterior case will be able to come off of the rest of the casing.
  • Look at the image in Step 7 for clarification on how the exterior case disassembles.
Insérez ici votre traduction
