Aller au contenu principal
Info : Vous modifiez un tutoriel pré-requis. Toutes les modifications apportées affecteront les tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 5
Étape 5
Insert the flat end of the spudger between the bottom body of the Chromebook and keyboard body. Slide the spudger along the gap, applying downward pressure to separate the two components.
  • Insert the flat end of the spudger between the bottom body of the Chromebook and keyboard body.
  • Slide the spudger along the gap, applying downward pressure to separate the two components.
  • You should hear popping sounds as you slide the spudger along the edge.
  • If the spudger gets stuck while sliding, simply slide the spudger back for a bit, and continue sliding forward.
Insérez ici votre traduction
