Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 10 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 5
Étape 5
Insert a pry tool gently between the top cover and metal casing on both sides to prepare the cover for removal. This step is necessary because you need to pry interior rivets away from the exterior case. The interior rivets that that hold the case in place are circled in the last image. After you gently pry in the areas demonstrated, the side panel of the exterior case will be able to come off of the rest of the casing. Look at the image in Step 7 for clarification on how the exterior case disassembles.
  • Insert a pry tool gently between the top cover and metal casing on both sides to prepare the cover for removal.
  • This step is necessary because you need to pry interior rivets away from the exterior case. The interior rivets that that hold the case in place are circled in the last image. After you gently pry in the areas demonstrated, the side panel of the exterior case will be able to come off of the rest of the casing.
  • Look at the image in Step 7 for clarification on how the exterior case disassembles.
Insérez ici votre traduction
