Aller au contenu principal
Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 4 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 6
Étape 6
With the front side (with the lens) facing up towards you, start at the bottom of the camera and gently pull off the front of the casing. The nob that previously held the camera strap will no longer be attached to the camera once you remove the camera casing. When putting the camera back together, remember to put the nob back into position before replacing the casing. The nob that previously held the camera strap will no longer be attached to the camera once you remove the camera casing. When putting the camera back together, remember to put the nob back into position before replacing the casing.
  • With the front side (with the lens) facing up towards you, start at the bottom of the camera and gently pull off the front of the casing.
  • The nob that previously held the camera strap will no longer be attached to the camera once you remove the camera casing. When putting the camera back together, remember to put the nob back into position before replacing the casing.
La face avant (avec l'objectif) tournée vers vous, commencez par le bas de l'appareil photo et retirez doucement l'avant du boîtier.
La poignée qui tenait auparavant la dragonne de l'appareil photo ne sera plus attachée à l'appareil photo une fois que vous aurez retiré le boîtier de l'appareil photo. Lors du remontage de la caméra, n'oubliez pas de remettre la poignée en place avant de replacer le boîtier.
