Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Info : Vous modifiez actuellement un prérequis du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 5 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 6
Étape 6
Squeeze the two optical drive bracket ears together while pulling the drive up toward yourself. It may be helpful to hold the logic board down near the optical drive connector when pulling the drive toward yourself to avoid both components lifting together.
  • Squeeze the two optical drive bracket ears together while pulling the drive up toward yourself.
  • It may be helpful to hold the logic board down near the optical drive connector when pulling the drive toward yourself to avoid both components lifting together.
  • Pull the optical drive away from the side of the rear case and remove it from the iMac.
  • If your optical drive is particularly stubborn to remove, try the method used in the optical drive guide from the A1144 G5 iMac.
Insérez ici votre traduction
