Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Anglais
Français
Traduction de l’étape 1
Étape 1
Insert the pointed tip of a spudger into the corner of the sensor array, between the case and the array. Pry up the sensor array. Remove the sensor array. Remove the sensor array.
  • Insert the pointed tip of a spudger into the corner of the sensor array, between the case and the array. Pry up the sensor array.
  • Remove the sensor array.
Insérez l'extrémité pointue d'une spatule (spudger) dans le coin de l'ensemble capteurs, entre la coque et l'ensemble. Faites levier.
Retirez l'ensemble capteurs.
