Aller au contenu principal
Info : Vous modifiez actuellement un pré-requis du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 14 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 1
Étape 1
Opening your phone will compromise its waterproof seals. Have replacement adhesive ready before you proceed, or take care to avoid liquid exposure if you reassemble your phone without replacing the adhesive.
  • Opening your phone will compromise its waterproof seals. Have replacement adhesive ready before you proceed, or take care to avoid liquid exposure if you reassemble your phone without replacing the adhesive.
  • Heat an iOpener and apply it to a long edge of the S8 for about 2 minutes.
  • You may need to reheat and reapply the iOpener several times to get the phone warm enough. Follow the iOpener instructions to avoid overheating.
  • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the OLED display and internal battery are both susceptible to heat damage.
  • As you're waiting for the adhesive to soften, move on and read the following step to get an idea of where to pry.
Posez un iOpener chauffé sur le bord long du S8 pendant environ 2 minutes.
Vous devrez peut-être refaire chauffer et reposer l'iOpner plusieurs fois jusqu'à ce que le téléphone soit suffisamment chaud. Suivez les instructions concernant l'iOpener pour éviter de le surchauffer.
Si vous attendez que l'adhésif ramollisse, allez vers l'avant et lisez l'étape suivante pour voir où vous devrez faire levier.
[* icon_note] Opening your phone will compromise its waterproof seals. Have replacement adhesive ready before you proceed, or take care to avoid liquid exposure if you reassemble your phone without replacing the adhesive.
black] Apply a heated iOpener[guide|25705|Heat an iOpener|new_window=true] and apply it to a long edge of the S8 for about 2 minutes.
[* icon_note] You may need to reheat and reapply the iOpener several times to get the phone warm enough. Follow the iOpener instructions to avoid overheating.
[* icon_caution] A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the OLED display and internal battery are both susceptible to heat damage.
[* icon_note] As you're waiting for the adhesive to soften, move on and read the following step to get an idea of where to pry.
