Aller au contenu principal
Info : Vous modifiez actuellement un pré-requis du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 14 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 8
Étape 8
Follow this guide to reinstall the back cover and replace the adhesive.
  • Follow this guide to reinstall the back cover and replace the adhesive.
  • Be sure to turn on your phone and test your repair before installing new adhesive and resealing the phone.
  • If desired, you may reinstall the back cover without replacing the adhesive. Remove any large chunks of adhesive that might prevent the back cover from sitting down flush. After installation, heat the back cover and apply pressure to secure it. It won't be waterproof, but the glue is usually more than strong enough to hold.
Avant de remplacer la vitre arrière, vous devez retirer tous les résidus d'adhésif de la partie principale du téléphone.
Une fois les résidus d'adhésif enlevés, nettoyez les bords du téléphone avec de l'alcool isopropylique à haute concentration (au moins 90 %) et appliquez une nouvelle couche d'adhésif.
[* icon_reminder] Before replacing your rear glass you will need[guide|124003|Follow this guide|new_window=true] to removereinstall the old adhesive fromback cover and replace the phone bodyadhesive.
[* black] After removingicon_note] Be sure to turn on your phone and test your repair before installing new adhesive and resealing the old adhesive, cleanphone.
[* icon_note] If desired, you may reinstall
the edgesback cover without replacing the adhesive. Remove any large chunks of adhesive that might prevent the phone body with high concentration isopropyl alcohol (at least 90%), thenback cover from sitting down flush. After installation, heat the back cover and apply pressure to secure it. It won't be waterproof, but the new adhesiveglue is usually more than strong enough to hold.
