Aller au contenu principal
Anglais
Français
Traduction de l’étape 1
Étape 1
Rotate the camera such that the flash unit and capacitor are facing you. DO NOT touch the capacitor because it may shock you. Remove the 3.5mm screw located between the flash unit and the capacitor.
  • Rotate the camera such that the flash unit and capacitor are facing you.
  • DO NOT touch the capacitor because it may shock you.
  • Remove the 3.5mm screw located between the flash unit and the capacitor.
Faites pivoter l'appareil photo de sorte que le flash et le condensateur soient face à vous.
NE touchez PAS le condensateur car il pourrait vous choquer.
Retirez la vis de 3,5 mm située entre le flash et le condensateur.
