Aller au contenu principal
Anglais
Français
Traduction de l’étape 3
Étape 3
Before removing the spark plug, used compressed air to clear the area around the plug of any dirt or debris. It's important to keep debris out of the cylinders, as it could cause serious engine damage. Place a 13/16" spark plug socket over the spark plug and make sure the spark plug is securely seated in the socket.
  • Before removing the spark plug, used compressed air to clear the area around the plug of any dirt or debris.
  • It's important to keep debris out of the cylinders, as it could cause serious engine damage.
  • Place a 13/16" spark plug socket over the spark plug and make sure the spark plug is securely seated in the socket.
  • Spark plug sockets have a rubber seat that protects the brittle spark plug when it's being removed from the engine.
  • Gently loosen the spark plug by slowly turning the wrench counterclockwise. Once the spark plug is free, remove it and set it aside.
  • Never use air tools to remove spark plugs, as the large amount of torque will break the spark plugs while they are still in the engine.
Insérez ici votre traduction
