Aller au contenu principal
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront les 6 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 1
Étape 1
With the blue plastic opening tool, use the lock screen switch by the volume button as an access point to gently lift the back cover off. Wedge the opening tool until you start hearing the back cover popping off the body of the device. Slide the opening tool down the length of the device.
  • With the blue plastic opening tool, use the lock screen switch by the volume button as an access point to gently lift the back cover off.
  • Wedge the opening tool until you start hearing the back cover popping off the body of the device.
  • Slide the opening tool down the length of the device.
  • Once it is about half way off, you can use your thumb to pull the rest of the back cover off.
Insérez ici votre traduction
