Aller au contenu principal
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront les 6 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 2
Étape 2
Using a Phillips #000 screwdriver, remove all 18 of the 4mm screws. With the blue plastic opening tool, gently wedge the tool between the screen and the gray frame until you feel resistance. Do not force the frame off because you can break off the teeth securing the frame to the screen.
  • Using a Phillips #000 screwdriver, remove all 18 of the 4mm screws.
  • With the blue plastic opening tool, gently wedge the tool between the screen and the gray frame until you feel resistance.
  • Do not force the frame off because you can break off the teeth securing the frame to the screen.
  • Push in the teeth with the blue plastic opening tool, towards the center of the device, and gently pull off the frame.
  • The gray frame will still be connected to the device by a pair of wires from the motherboard to the speaker.
Insérez ici votre traduction
