Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront le tutoriel qui comprend ces étapes.
Anglais
Français
Traduction de l’étape 1
Étape 1
If you're installing a new rear glass panel, you'll also need to transfer the fingerprint sensor to your new rear glass panel as follows: Reheat an iOpener and apply it to the fingerprint sensor mounted to the rear glass. Push the fingerprint sensor off of its adhesive from the outside of the glass.
  • If you're installing a new rear glass panel, you'll also need to transfer the fingerprint sensor to your new rear glass panel as follows:
  • Reheat an iOpener and apply it to the fingerprint sensor mounted to the rear glass.
  • Push the fingerprint sensor off of its adhesive from the outside of the glass.
  • If the sensor is stubborn, gently slide a halberd spudger or opening pick under the plastic backing to loosen the adhesive before pushing.
  • This will make the adhesive less likely to be reusable, so try pushing with your finger first.
Réchauffez un iOpener et appliquez-le au capteur d'empreinte digitale monté sur la vitre arrière.
Enlevez le capteur d'empreinte digitale de son adhésif de l'extérieur de la vitre.
Si le capteur est récalcitrant, faites glisser délicatement une spatule (spudger) sous le support en plastique pour desserrer l'adhésif avant de pousser.
Cela rend l'adhésif moins susceptible d'être réutilisable, alors essayez de pousser d'abord avec votre doigt.
[* black] If you're installing a new rear glass panel, you'll also need to transfer the fingerprint sensor to your new rear glass panel as follows:
black] Reheat an iOpener and apply it to the fingerprint sensor mounted to the rear glass.
black] Push the fingerprint sensor off of its adhesive from the outside of the glass.
[* black] If the sensor is stubborn, gently slide a halberd spudger or opening pick under the plastic backing to loosen the adhesive before pushing.
[* icon_note] This will make the adhesive less likely to be reusable, so try pushing with your finger first.
