Aller au contenu principal
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront le tutoriel qui comprend ces étapes.
Anglais
Français
Traduction de l’étape 2
Étape 2
Connect the spark plug wires to the new distributor cap one at a time. Mixing up the order will result in the engine not firing properly or at all. Pull straight up on the boot of the first spark plug wire to disconnect it from the distributor cap. Be sure to pull on the boot and not the wire itself. Spark plug wires are quite fragile and may break easily.
  • Connect the spark plug wires to the new distributor cap one at a time. Mixing up the order will result in the engine not firing properly or at all.
  • Pull straight up on the boot of the first spark plug wire to disconnect it from the distributor cap.
  • Be sure to pull on the boot and not the wire itself. Spark plug wires are quite fragile and may break easily.
Insérez ici votre traduction
