Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Anglais
Français
Traduction de l’étape 2
Étape 2
Using a soldering iron set at 400 degrees Celsius (752 degrees Fahrenheit), heat the solder joints lateral to the USB port. Use a pair of tweezers to lift the port from the board.
  • Using a soldering iron set at 400 degrees Celsius (752 degrees Fahrenheit), heat the solder joints lateral to the USB port. Use a pair of tweezers to lift the port from the board.
  • Extreme caution should be taken when working with high-temperature equipment to reduce the chance of burns.
  • Care should be taken while desoldering the joints as the heat could melt the plastic casing on the port. It is strongly recommended that soldering surface-mounted components guide is referenced before proceeding.
Insérez ici votre traduction
