Aller au contenu principal
Anglais
Français
Traduction de l’étape 9
Étape 9
Retina Macbook 2016 Repairability Score: 1 out of 10 (10 is the easiest to repair)
Final Thoughts
  • Retina Macbook 2016 Repairability Score: 1 out of 10 (10 is the easiest to repair)
  • Apple did not return to tri-point screws, and instead used only Torx and Phillips screws within the computer.
  • The processor, RAM, and flash memory are still soldered to the logic board.
  • A large amount of strong adhesive holds the battery assembly to the lower case .
  • The Retina display is a fused unit with no separate, protective glass. If the display is damaged, it'll be arduous and expensive to repair.
  • While it's no more repairable than the last two years' editions, it does benefit from sharing a lot of the same parts and repair procedures as the other Retina MacBooks.
Insérez ici votre traduction
