Aller au contenu principal
Fix Your Stuff
Right to Repair
Parts & Tools
Info : Vous modifiez actuellement un prérequis du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 9 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 2
Étape 2
Gently place an opening pick in the corner of the gap between the bottom casing and rear case. Slide the opening pick along the side of the casing, prying it away from the adhesive as you go. Slide the opening pick along the side of the casing, prying it away from the adhesive as you go.
  • Gently place an opening pick in the corner of the gap between the bottom casing and rear case.
  • Slide the opening pick along the side of the casing, prying it away from the adhesive as you go.
Insérez ici votre traduction
