Aller au contenu principal
Info : Vous modifiez actuellement un pré-requis du tutoriel que vous venez de consulter. Toutes les modifications affecteront le tutoriel% qui comprend cette étape.
Traduction de l’étape 2
Étape 2
Using a plastic opening tool, carefully pry up the bottom of the display glass. Slowly work your way around the phone, using the plastic opening tool to separate the glass from the phone. As you work, the adhesive may cool and harden.  You may need to heat up the glass again as you work your way around the screen.
  • Using a plastic opening tool, carefully pry up the bottom of the display glass.
  • Slowly work your way around the phone, using the plastic opening tool to separate the glass from the phone.
  • As you work, the adhesive may cool and harden. You may need to heat up the glass again as you work your way around the screen.
Insérez ici votre traduction
