Aller au contenu principal
Info : Vous modifiez actuellement un pré-requis du tutoriel que vous venez de consulter. Toutes les modifications affecteront le tutoriel% qui comprend cette étape.
Traduction de l’étape 4
Étape 4
Now that the cable has been removed you can slide it through the opening and detach the glass. Be careful as you pull the cable through the opening. The cable is easily damaged. Once the cable is pushed through the slot, the glass can be fully removed.
  • Now that the cable has been removed you can slide it through the opening and detach the glass.
  • Be careful as you pull the cable through the opening. The cable is easily damaged.
  • Once the cable is pushed through the slot, the glass can be fully removed.
Insérez ici votre traduction
