Aller au contenu principal
Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 21 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 4
Étape 4
With the display panel still lifted, disconnect the four inverter cables. During reinstallation, place the four inverter cable connectors in voids between components attached to the rear panel so the display panel will sit flush on the edges of the rear case.
  • With the display panel still lifted, disconnect the four inverter cables.
  • During reinstallation, place the four inverter cable connectors in voids between components attached to the rear panel so the display panel will sit flush on the edges of the rear case.
  • (combined into one plug in on the 24")
  • Be sure to keep track of the cables, as they do not have proprietary sockets. Mismatched cables can cause screen issues.
Pendant que l'écran est levé, débranchez les quatre câbles inverter.
Pendant la réinstallation, placez les quatre connecteurs des câbles inverter dans des espaces vides entre les composants attachés au panneau arrière afin que l'écran repose bien à plat sur les rebords du panneau arrière.
(combinés dans une seule et même fiche de connexion sur le modèle 24")
[* black] With the display panel still lifted, disconnect the four inverter cables.
[* icon_reminder] During reinstallation, place the four inverter cable connectors in voids between components attached to the rear panel so the display panel will sit flush on the edges of the rear case.
[* black] (combined into one plug in on the 24")
+[* icon_caution] Be sure to keep track of the cables, as they do not have proprietary sockets. Mismatched cables can cause screen issues.
