Aller au contenu principal
Anglais
Français
Traduction de l’étape 5
Étape 5
When you remove this screw, make sure that the shield plate on top of the bracket plate, is just slightly pushed out of the way. This will free the bracket plate. After the removal of the bracket plate, you have access to the connector. Move the white clip gently to the lift (upright) position, to free the cable. The LCD should now easily separate from the logic board.
  • When you remove this screw, make sure that the shield plate on top of the bracket plate, is just slightly pushed out of the way. This will free the bracket plate.
  • After the removal of the bracket plate, you have access to the connector. Move the white clip gently to the lift (upright) position, to free the cable.
  • The LCD should now easily separate from the logic board.
Insérez ici votre traduction
