Aller au contenu principal
Info : Vous modifiez actuellement un pré-requis du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 5 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 4
Étape 4
Disconnect the hard drive data cable connector from the logic board by pulling it straight up from its socket.
  • Disconnect the hard drive data cable connector from the logic board by pulling it straight up from its socket.
  • The SATA connector on most iMacs tends to stick in its socket on the logic board. If you are having trouble disconnecting the SATA cable, insert a metal spudger or any other thin tool into the gap between the SATA connector and its socket and twist the spudger's shaft to safely separate the two pieces.
Insérez ici votre traduction
