Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront les 2 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 5
Étape 5
The home button's ribbon cable is very fragile. If it gets damaged, or if the home button has to be replaced, Touch ID will no longer function. Use an iOpener, heat gun, or hair dryer to soften the adhesive under the cable before you pry it up. Starting from the ZIF connector, use the blade on a halberd spudger or the edge of an opening pick to separate the home button cable from the adhesive holding it in place. Stop when you reach the home button.
  • The home button's ribbon cable is very fragile. If it gets damaged, or if the home button has to be replaced, Touch ID will no longer function.
  • Use an iOpener, heat gun, or hair dryer to soften the adhesive under the cable before you pry it up.
  • Starting from the ZIF connector, use the blade on a halberd spudger or the edge of an opening pick to separate the home button cable from the adhesive holding it in place. Stop when you reach the home button.
En partant du connecteur ZIF, utilisez la lame d'une spatule hallbarde s(halberd spudger) ou le bord d'un médiator pour retirer l'adhésif maintenant la nappe du bouton home. Arrêtez lorsque vous atteignez le bouton home.
[* icon_caution] The home button's ribbon cable is '''very''' fragile. If it gets damaged, or if the home button has to be replaced, Touch ID will no longer function.
[* black] Use an iOpener, heat gun, or hair dryer to soften the adhesive under the cable before you pry it up.
black] Starting from the ZIF connector, use the blade on a halberd spudger or the edge of an opening pick to remove the adhesive holdingseparate the home button cable from the adhesive holding it in place. Stop when reachingyou reach the home button.
