Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront les 2 tutoriels qui comprennent cette étape.
Traduction de l’étape 7
Étape 7
Remove the home button bracket.
Scrape off as much of the old adhesive residue as you can, then clean it with acetone or high-concentration (90% or greater) isopropyl alcohol.
Secure the bracket with hot-melt glue, superglue, or high-strength double-sided tape. Make sure the bracket is aligned correctly before allowing your adhesive to cure, or the home button will not click when pressed.
[* black] Remove the home button bracket. |
[* icon_reminder] During reassembly, after installing the home button, you'll need to glue this bracket into place to secure it. |
[* black] Scrape off as much of the old adhesive residue as you can, then clean it with acetone or high-concentration (90% or greater) isopropyl alcohol. |
[* black] Secure the bracket with hot-melt glue, superglue, or [product|IF317-072|high-strength double-sided tape]. Make sure the bracket is aligned correctly before allowing your adhesive to cure, or the home button will not click when pressed. |
