Aller au contenu principal
Anglais
Français
Traduction de l’étape 12
Étape 12
Slide an opening pick or thin pry tool underneath the top portion of the Lightning connector assembly flex cable, and begin separating it from the rear case. If necessary, use a hair dryer or apply an iOpener to heat the rear case and soften the adhesive, in order to make it easier to separate. If necessary, use a hair dryer or apply an iOpener to heat the rear case and soften the adhesive, in order to make it easier to separate.
  • Slide an opening pick or thin pry tool underneath the top portion of the Lightning connector assembly flex cable, and begin separating it from the rear case.
  • If necessary, use a hair dryer or apply an iOpener to heat the rear case and soften the adhesive, in order to make it easier to separate.
Faites glisser un médiator ou un outil mince en dessous de la partie supérieure de la nappe du connecteur de charge Lightning et commencez à la décoller de la coque arrière.
Si nécessaire, utilisez un sèche-cheveux ou appliquez un iOpener pour chauffer la coque arrière et ramollir l'adhésif, afin de faciliter la séparation.
