Aller au contenu principal
Anglais
Français
Traduction de l’étape 17
Étape 17
A rubber gasket on the bottom of the Lightning connector protects your iPhone from liquid and dust intrusion. If you are installing a new Lightning connector assembly, you may need to carefully remove and transfer the gasket to the new part. The small adhesive patch on the bottom of each microphone also protects your iPhone from liquid and dust intrusion. For best results, replace the two adhesive patches before installing your Lightning connector assembly. The small adhesive patch on the bottom of each microphone also protects your iPhone from liquid and dust intrusion. For best results, replace the two adhesive patches before installing your Lightning connector assembly.
  • A rubber gasket on the bottom of the Lightning connector protects your iPhone from liquid and dust intrusion. If you are installing a new Lightning connector assembly, you may need to carefully remove and transfer the gasket to the new part.
  • The small adhesive patch on the bottom of each microphone also protects your iPhone from liquid and dust intrusion. For best results, replace the two adhesive patches before installing your Lightning connector assembly.
Un joint en caoutchouc au fond du connecteur de charge Lightning protège votre iPhone de l'intrusion de liquide et de poussières. Si vous installez un nouvel ensemble de connecteur de charge Lightning, vous devrez peut-être retirer et transférer soigneusement le joint sur la nouvelle pièce.
Le petit patch adhésif au fond de chaque microphone protège également votre iPhone de l'intrusion de liquide et de poussières. Pour de meilleurs résultats, remplacez les deux patchs adhésifs avant d'installer votre ensemble connecteur de charge Lightning.
