Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Info : Vous modifiez actuellement un prérequis du tutoriel que vous venez de consulter. Toutes les modifications affecteront le tutoriel% qui comprend cette étape.
Traduction de l’étape 3
Étape 3
Slide the tip of a spudger underneath the proximity sensor flex cable, and lift the sensor out of its housing. Slide the tip of a spudger underneath the proximity sensor flex cable, and lift the sensor out of its housing. Slide the tip of a spudger underneath the proximity sensor flex cable, and lift the sensor out of its housing.
  • Slide the tip of a spudger underneath the proximity sensor flex cable, and lift the sensor out of its housing.
Faites glisser la pointe d'un spudger sous la nappe du capteur de luminosité ambiante et soulevez le capteur hors de son emplacement.
[* black] Slide the tip of a spudger underneath the ambient lightproximity sensor flex cable, and lift the sensor out of its housing.
