Aller au contenu principal
Fix Your Stuff
Right to Repair
Parts & Tools
Info : Vous modifiez actuellement un prérequis du tutoriel que vous venez de consulter. Toutes les modifications affecteront le tutoriel% qui comprend cette étape.
Traduction de l’étape 5
Étape 5
Insert the point of a spudger underneath the same portion of the flex cable that you separated in the previous step. Continue separating the remainder of the flex cable, pushing the spudger toward the row of circular gold earpiece speaker contacts. Continue separating the remainder of the flex cable, pushing the spudger toward the row of circular gold earpiece speaker contacts.
  • Insert the point of a spudger underneath the same portion of the flex cable that you separated in the previous step.
  • Continue separating the remainder of the flex cable, pushing the spudger toward the row of circular gold earpiece speaker contacts.
Insérez la pointe d'un spudger sous la partie de la nappe flexible que vous avez décollée à l'étape précédente.
Continuez à séparer la nappe, en poussant le spudger vers la bande des contacts ronds en or du haut-parleur interne.
[* black] Insert the point of a spudger underneath the same portion of the flex cable that you separated in the previous step.
[* black] Continue separating the remainder of the flex cable, pushing the spudger toward the striprow of circular gold earpiece speaker contacts.
