Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Anglais
Français
Remplacement de l'écran LCD et de la vitre tactile de l'iPhone 7 Plus
Informations sur le tutoriel
= Terminé = Incomplet
LCD Screen and Digitizer
LCD Screen and Digitizer Replacement
    Use this guide to replace a cracked or broken screen in an iPhone 7 Plus. This includes removing the [https://www.ifixit.com/Guide/iPhone+7+Plus+Front+Camera+and+Sensor+Cable+Replacement/95688|front-facing camera|new_window=true], [https://www.ifixit.com/Guide/iPhone+7+Plus+Earpiece+Speaker+Replacement/95614|earpiece speaker|new_window=true], [https://www.ifixit.com/Guide/iPhone+7+Plus+LCD+Screen+and+Digitizer+Replacement/96109#s177734|LCD shield plate|new_window=true], and home/Touch ID sensor assembly—all of which must be transferred to your new display. ForFor an easier repair, use our [product|IF333-038|fix kit|new_window=true] and follow [guide|67563|this shorter guide] to replace the your iPhone’s entire display assembly instead by following [https://www.ifixit.com/Guide/iPhone+7+Plus+Display+Assembly+Replacement/67563|this much shorter guide]. screen. [ … ] In either case,For more advanced fixers, this guide will help you replace ''only'' the iPhone 7 Plus LCD and digitizer assembly (a.k.a. the bare “front panel”). This requires you to transfer several components from your original screen to the new one before installing it—including the [guide|95688|front-facing camera|new_window=true], [guide|95614|earpiece speaker|new_window=true], [guide|96109|LCD shield plate|stepid=177734|new_window=true], and home/Touch ID sensor assembly. [ ] For all screen/display repairs, '''it's important to carefully transfer the original home/Touch ID sensor onto the new display in order for it to function.''' function.''' The solid state home button is paired to its original logic board by Apple, so replacing it will render it unusable.
      ToCompare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before installing. [ ] '''To reassemble your device, follow these instructions the above steps in reverse order. order.''' [ ] Take your e-waste to an [[E-Waste|R2 or e-Stewards certified recycler|new_window=true]]. [ ] Repair didn’t go as planned? Try some [https://www.ifixit.com/Wiki/Troubleshooting_Problems_After_a_Repair|basic troubleshooting], or search our [https://www.ifixit.com/Answers/Device/iPhone%207%20Plus|Answers forum] for help.
      Décrivez la pièce ou le composant spécifique de ce device sur lequel vous êtes en train de travailler. Par ex : batterie
      Créer un titre.
      Ce bref résumé n'apparaîtra que dans les résultats de recherche.
      Communiquez des informations de base avant que le lecteur ne se plonge dans le tutoriel.
      Étapes du tutoriel
      Étape 1
      Retirez la partie supérieure rectangulaire de l'autocollant de la plaque de protection de l'écran LCD pour la séparer de la nappe en dessous.
      Étape 2
      Utilisez un tournevis Y000 pour enlever trois vis de 1,1 mm d'un côté du blindage électromagnétique (EMI) de l'écran.
      Étape 3
      Utilisez un tournevis Y000 pour enlever deux vis supplémentaires de 1,1 mm de l'autre côté du blindage EMI.
      Étape 4
      Retirez la vis cruciforme de 1,8 mm fixant le blindage électromagnétique (EMI) près du bas de l'écran.
      Étape 5
      Soulevez la plaque de protection de l'écran LCD tout en appuyant sur la nappe qu'elle entoure.
      Étape 6
      Retirez la plaque de protection de l'écran LCD.
      Étape 7
      Il ne reste que l'écran LCD et la vitre tactile.
