Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Anglais
Français
Traduction de l’étape 5
Étape 5
Here's were it can get tricky. Of course the correct way to replace this is to completely evacuate the system and remove the evaporator but with a little ingenuity you can have it replaced in 10 minutes. Open the evaporate shell by splitting the halves. I used a spring clamp, backwards, to help me hold the halves open. Using a long pair of needle nose pliers, gently work the Thermistor out of the evaporate fins.
  • Here's were it can get tricky. Of course the correct way to replace this is to completely evacuate the system and remove the evaporator but with a little ingenuity you can have it replaced in 10 minutes.
  • Open the evaporate shell by splitting the halves. I used a spring clamp, backwards, to help me hold the halves open.
  • Using a long pair of needle nose pliers, gently work the Thermistor out of the evaporate fins.
Insérez ici votre traduction
