Aller au contenu principal
Anglais
Français
Traduction de l’étape 1
Étape 1
It's difficult to remove this bottom bracket. The inside round edge of this bracket seems to be soldered with camera lens ring; so you need much more effort and it's not surprising to break the bracket altogether. I like to take a flat screw driver and push it in where it wont damage any components and just pull until I hear small tears. Thats where the soldering have happened, you can also see it in picture three.
Camera bottom bracket
  • It's difficult to remove this bottom bracket. The inside round edge of this bracket seems to be soldered with camera lens ring; so you need much more effort and it's not surprising to break the bracket altogether.
  • I like to take a flat screw driver and push it in where it wont damage any components and just pull until I hear small tears.
  • Thats where the soldering have happened, you can also see it in picture three.
Il est difficile de retirer ce support. Le bord intérieur rond de ce support semble soudé à l'anneau de la lentille de la caméra. Vous avez donc besoin de beaucoup d'efforts et il n'est pas surprenant de casser le support en même temps.
J'aime prendre un tournevis plat et le pousser là où il n'endommagera aucun composant et le retirer jusqu'à ce que j'entende de petits craquèlements.
C'est là où se trouve la soudure, vous pouvez aussi la voir sur la troisième image.
