Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Anglais
Français
Traduction de l’étape 3
Étape 3
Starting with the bottom end, there are eleven hex screws with ball heads which are holding down the metal plate on top of the battery block and the keyboard unit will snap on to. With the help of our 64 Bit Driver Kit we get a glimpse on the battery pack which consist out of four separate batteries cuddling under a black adhesive strip. With the help of our 64 Bit Driver Kit we get a glimpse on the battery pack which consist out of four separate batteries cuddling under a black adhesive strip.
  • Starting with the bottom end, there are eleven hex screws with ball heads which are holding down the metal plate on top of the battery block and the keyboard unit will snap on to.
  • With the help of our 64 Bit Driver Kit we get a glimpse on the battery pack which consist out of four separate batteries cuddling under a black adhesive strip.
En commençant en bas, nous comptons onze vis hexagonales à tête sphérique, qui maintiennent la plaque de métal au-dessus du bloc batterie et sur laquelle le module du clavier s'enclenche.
À l'aide du kit de 64 embouts de tournevis, nous avons un aperçu du bloc batterie qui se compose de quatre batteries distinctes, maintenues par une bande adhésive noire.
