Traduction de l’étape 4
Étape 4
Troubleshooting
If you are having trouble desoldering here are the two things you can do to solve.
You can use a screw driver to open the resistors and then remove them from the board allowing access to the ground pins
Now using snips you can cut the pins and then use a soldering iron to both sides and remove the cut pin gently with pliers
