Aller au contenu principal
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront le tutoriel qui comprend ces étapes.
Anglais
Français
Traduction de l’étape 8
Étape 8
Open the device between 90 and 100 degrees, then rest it on its side. While supporting both halves of the device with one hand, unscrew the upper 5.3 mm T8 Torx screw.
  • Open the device between 90 and 100 degrees, then rest it on its side.
  • While supporting both halves of the device with one hand, unscrew the upper 5.3 mm T8 Torx screw.
  • Repeat the same process for the identical bottom screw.
  • Be sure to hold the display and upper case together with one hand. Failure to do so may cause the freed display/upper case to fall, potentially damaging each component.
Insérez ici votre traduction
