Aller au contenu principal
Anglais
Français
Traduction de l’étape 4
Étape 4
Install new fabric: If the board is damaged, repair it using aluminum tape. Any rough areas might show after the new fabric is applied. Lay out the new fabric over the board. Pull 1/2 of it back over itself.
  • Install new fabric:
  • If the board is damaged, repair it using aluminum tape. Any rough areas might show after the new fabric is applied.
  • Lay out the new fabric over the board. Pull 1/2 of it back over itself.
  • Spray headliner adhesive glue on 1/2 of the board and the back side of the fabric.
  • Carefully place the fabric onto the board starting from the center point and smooth it outward wit your hand as you lay it down.
  • Pull up the other 1/2of the fabric over the side you just glued down. Repeat the above steps to lay down this side of the fabric.
Insérez ici votre traduction
