Aller au contenu principal
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront le tutoriel qui comprend ces étapes.
Anglais
Français
Traduction de l’étape 6
Étape 6
Just a few turns from our Phillips and tri-point drivers and the display is free ... to hit the bench. For the full scoop on the display, check out our iPhone 8 Teardown. Our parts testing crew reports that the 8 and 8 Plus use the exact same home button part, which should make that particular replacement part a little easier to source. We successfully yanked 3 out of 4 adhesive tabs when removing the battery—leaving one stubbornly in place. Looks like Apple's decision to switch to four tabs from two was to avoid a sticky situation on that fancy new wireless charging coil.
  • Just a few turns from our Phillips and tri-point drivers and the display is free ... to hit the bench. For the full scoop on the display, check out our iPhone 8 Teardown.
  • Our parts testing crew reports that the 8 and 8 Plus use the exact same home button part, which should make that particular replacement part a little easier to source.
  • We successfully yanked 3 out of 4 adhesive tabs when removing the battery—leaving one stubbornly in place. Looks like Apple's decision to switch to four tabs from two was to avoid a sticky situation on that fancy new wireless charging coil.
  • Speeding right along, we pull out that factory-calibrated-for-AR dual camera unit.
  • These 12 MP cameras are solidly fixed together, enabling software used for portrait mode to combine images from both lenses.
Quelques petits coups de nos tournevis cruciforme et tri-point et l'écran s'enlève … Pour tout savoir sur l'écran, allez voir la vue éclatée de l'iPhone 8.
Selon notre équipe responsable des tests des composants, le 8 et le 8 Plus ont le même bouton home, ce qui facilitera un peu l'approvisionnement de cette pièce précise.
Nous réussissons à retirer 3 des 4 bandes adhésives en enlevant la batterie – la dernière s'obstine à rester sur place. On dirait qu'Apple a décidé de passer de deux à quatre languettes pour éviter d'encoller trop la rutilante bobine de recharge sans fil.
Nous passons en vitesse supérieure et sortons l'ensemble de la caméra double calibrée en usine pour être compatible avec la Réalité Augmentée.
Ces caméras de 12 MP sont solidement collées ensemble, ce qui permet au logiciel du mode portrait de combiner les images des deux lentilles.
