Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront le tutoriel qui comprend ces étapes.
Anglais
Français
Traduction de l’étape 6
Étape 6
Use a plastic opening tool in the indicated location and apply pressure until the case hook is detached. Then lift the case up until the two pieces are detached. Use a plastic opening tool in the indicated location and apply pressure until the case hook is detached. Then lift the case up until the two pieces are detached. Use a plastic opening tool in the indicated location and apply pressure until the case hook is detached. Then lift the case up until the two pieces are detached.
  • Use a plastic opening tool in the indicated location and apply pressure until the case hook is detached. Then lift the case up until the two pieces are detached.
Utilisez un outil d'ouverture en plastique dans l'emplacement indiqué et appliquez une pression jusqu'à ce que le crochet de boîtier soit détaché. Ensuite, soulevez le boîtier jusqu'à ce que les deux pièces soient détachées.
