Aller au contenu principal
Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 6 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 5
Étape 5
Support the display with one hand and remove the single Phillips screw on either side of the hinge (two screws total).
  • Support the display with one hand and remove the single Phillips screw on either side of the hinge (two screws total).
  • The screws go in the outer holes on each side (you can see the threads in the correct hole).
  • It may be necessary to unscrew one side of the optical drive for enough clearance to thread the AirPort antenna through the gap between the body of the optical drive and the iBook's internal frame.
  • When remounting, mind that cables pass under the hinge, not over
Insérez ici votre traduction
